Anonymous's avatar
8 years ago
Help Converting an Excel countifs function into Power BI
Hi all,
I am new to the forum and new to Power-Bi and I really need a little help.
I have been given an excel sheet and asked to convert it to Power-Bi. I am really stuck with 1 formula in particular.
The excel formula is...
=COUNTIFS($G$4:$G$2000,G4,$H$4:$H$2000,1)
Range = Aisle Column
Criteria = 1st Cell In Aisle Column
Range2 = Orderlines
Criteria2 = 1
I hope that this makes sense ?
Any help greatly appreciated.
  • v-jiascu-msft's avatar
    v-jiascu-msft
    Hi Anonymous,
    Actually, there are no concepts of cells and rows like Excel in Power BI. You can try it like below. Please post a sample here. Because we need a function like Max, Min etc. to determine the 1st cell in Aisle column.
    Measure =
        COUNTROWS ( Table1 ),
        FILTER ( Table1, Table1[Criteria1] = max(1st cell in Aisle column) && Table[Criteria2] = 1 )
    Dale
  • Hi Anonymous,
    This should be possible with a calculated column formula.  Share the link from where i can download your file.
      Thanks guys for taking the time to have a look and try to help :)
      Please try this link to the excel file. https://1drv.ms/x/s!AraHh-vwAl8dgU2WZDIaPRQmV0Bq
      and this link for the extract from Powerbi. https://1drv.ms/x/s!AraHh-vwAl8dgVE6xMUtsW9SsAQH
      I have managed to add an order line count. i still need the last 2 columns from the excel sheet adding to PowerBi .
      The Table i am using in PowerBi is called Orderwell Summary.
      • Zubair_Muhammad's avatar
        Zubair_Muhammad
        Hi Anonymous
        Try this calculated column for "number of single picks in aisle for single item orders"
        number of single picks =
        VAR check =
            COUNTROWS (
                FILTER (
                    ALL ( Orderwell_Summary ),
                    Orderwell_Summary[Column1] = EARLIER ( Orderwell_Summary[Column1] )
                        && Orderwell_Summary[no. order lines] = 1
            IF ( check >= 1, check, 0 )
