Help - Building Relationships between 2 data sets
- 9 years ago
Hi PowerBI-Curious,
In Power BI Desktop, you should be able to make use of LOOKUPVALUE DAX function to create a new calculate column in the second table, to get the corresponding person data in table A.
In addition, if there is a relationship between the two tables, you can also use RELATED or RELATEDTABLE DAX function to create the calculate column.
If have any question to create the calculate column, please post your table structures with some sample data and your expected result. :smileyhappy:
Regards
Hi PowerBI-Curious,
Regards
- PowerBI-Curious9 years ago
This worked, thankyou v-ljerr-msft
- v-ljerr-msft9 years ago
Hi PowerBI-Curious,
Great to hear the problem got resolved! Could you accept the reply as solution to close this thread? :smileyhappy:
Regards
