Gateway Connection Problem
- Anonymous2 years ago
Hi, Evans_Santos
Check your firewall settings to make sure that there are no firewall rules blocking the connection between the Power BI gateway and the PostgreSQL database. Sometimes, the firewall may drop packets which leads to this error.
You can try increasing the timeout setting in the Power BI connection string. You can check the following post:Solved: Postgresql: Exception while reading from stream - Microsoft Fabric Community
Install the npgsql provider to ensure that the npgsql provider is installed on the server that hosts the data gateway. This is required for the PostgreSQL connection to work properly. You can refer to the following post:Solved: Configure Gateway to connect to PostgreSQL - Microsoft Fabric Community
Yongkang Hua
How can I check to see if the user has access to the bank? I've tried everything but nothing has worked. I'm waiting if you can help.
- lbendlin2 years ago
Talk to your PostGreSQL database admin.
