jockefe
Advocate IV
9 years agoformat string percent does not work in power bi
I have a SSAS Olap cube with a calculated measure CREATE MEMBER CURRENTCUBE.[Measures].[percent test] AS 1/2 ,VISIBLE = 1 ,FORMAT_STRING = 'Percent'; This works fine in management studio a...
Hikmer
8 years agoWhat I am encountering, is that is WAS working...now it is not formating correctly. As of last week, visualizations no longer show percentages (we are using the "0.00%" and "0.0%" format strings). In Excel and PowerBI tables, the percent formating is correct. Only when using a PowerBI chart or visualizations is it not honoring the format string. It is way frustrating trying to figure out the problem.
LKoewing
6 years agoFrequent Visitor
Change the formatting of your calculated measure coming from your Multi Dimensional cube from "Percent" to "#.##%" for example, and test.
Worked for us.
