Fixed function Tableau to Power BI DAX help!
I need to convert this fixed LOD in tableau to DAX, can anyone help?
{ FIXED [Matter/Case ID# (GAL Permanency Goals)]:COUNT([Permanency Goal])}
- Anonymous2 years ago
Hi Anonymous ,
1. Create measure.
Average Permanency Goals Per Case = AVERAGEX( FILTER(ALL('Table'), 'Table'[Close Reason]=MAX('Table'[Close Reason])),[Total Permanency Goals (the measure from above)])2. Select [Measure] – Measure tools – Set the decimal point
3. Result:
Liu Yang
- AnonymousNot applicable
Hi Anonymous ,
I created some data:
Are you referring to the de-duplication counts for [Permanency Goal] grouped by [Matter/Case ID] in the table?
1. Create measure.
Measure = CALCULATE( DISTINCTCOUNT( 'Table'[Permanency Goal]), FILTER(ALL('Table'), 'Table'[Matter/Case ID]=MAX('Table'[Matter/Case ID])))2. Result:
If it doesn't meet your desired outcome, can you share sample data and sample output in table format? Or a sample pbix after removing sensitive data. We can better understand the problem and help you.
Liu Yang
This is exactly what I'm looking for, it worked perfectly - thank you!
Part 2 to this one - If I want to then calculate the average number of permanency goals per case based on the close reason, is that possible?
Below is what I'm trying to get to. So the top chart would be what I have with the formula you provided and then the bottom (in red) is what I need a DAX formula for.
Matter/Case ID Total Permanency Goals (the measure from above) Close Reason x 2 AD y 3 GU z 2 REU a 1 REU b 4 GU c 1 AD Close Reason Average Permanency Goals Per Case AD 1.5 GU 3.5 REU 1.5 THANKS!
Hi Anonymous ,
1. Create measure.
3. Result:
Liu Yang
- ryan_mayu
could you pls provide some sample data and expected output?
