Filter doesn't register same values as 1 after column split
- 2 years ago
Try applying trim function, also share sample data to check from my end,
NG
Hi Anonymous
since you use delimeter after comma, the Brandon, Abby get split and Abby has a space at the start. So trim the values to resolve this issue.
let me know if this helps.
If this post helps, then please consider Accept it as the solution to help the others find it more quickly. Appreciate you kudos!!
Follow me on LinkedIn!!!
Sorry there are no spaces between the values. I just added it with space for clarity sake.
There is linebreak between them. Would that affect the value?
I've checked the values themselves and there are no space and linebreaks before them.
- NaveenGandhi2 years ago
Memorable Member
NG
