Export Data from Power BI to csv does not work
Hi All,
from yesterday I cannot export data from my pbi reporting file to csv. Usually I've done it withour any problem.
What it is strange is that from some table I can, but from others not. When I run export data, it appears the window "working on it" but in some seconds it disappears and the usual window where I can save the file is not showed. This is not for all sheets/tables I have in the file.
Could you please help me in understanding how to solve it?
Rgds
GS
Hi Schigia
Possible Causes & Solutions:
1. Export Restrictions on Visuals
Some visuals have export limitations based on their structure:
- If a table contains too many rows (150,000+ for CSV export in Power BI Desktop), it might fail.
- If you're trying to export data from a Matrix, Power BI may restrict detailed-level exports.
Solution: Try exporting from a simpler Table visual instead of a Matrix or other complex visuals.
2. Row-Level Security (RLS) or Permissions Issue
If your report has Row-Level Security (RLS) or specific permissions, you may not be allowed to export certain data.
Solution: Check your data source permissions or try exporting with a user that has full access.
3. Data Export is Disabled in Power BI Settings
Power BI Desktop might have export restrictions enabled.
Solution:
- Go to File → Options and Settings → Options
- Under Current File → Report settings, check if "Export Data" is enabled.
4. Corrupted Visual or File
If a specific table or sheet is causing the issue, the file might have a corruption.
Solution:
- Try duplicating the table visual and export again.
- Create a new report and connect to the same data source.
- Export the data from the new report.
5. Power BI Version Issue
A Power BI update might have introduced a bug.
Solution:
- Update Power BI Desktop to the latest version from the Microsoft Store or the official website.
- If the issue started after an update, try rolling back to a previous version.
6. Data Volume Too Large
If you're dealing with very large datasets, Power BI might struggle to export them.
Solution:
- Try filtering the table before exporting.
- Use DAX measures to limit the data.
7. Software Conflicts
Some background processes may interfere with Power BI’s export functionality.
Solution:
- Close unnecessary applications.
- Restart Power BI and try again.
🌟 I hope this solution helps you unlock your Power BI potential! If you found it helpful, click 'Mark as Solution' to guide others toward the answers they need.
💡 Love the effort? Drop the kudos! Your appreciation fuels community spirit and innovation.
🎖 As a proud SuperUser and Microsoft Partner, we’re here to empower your data journey and the Power BI Community at large.
🔗 Curious to explore more? [Discover here].
Let’s keep building smarter solutions together!
- Vinnie
Facing the same issue:
I do not see this problem as solved since it looks like it is a bug in the newer version.
- S_B_1246Regular Visitor
I am having the same problem, when i filter the data it seems to work but when i dont the export loading screen just dissapears. The largest working export contains 5000 rows
- BrubakerM
Advocate I
FYI - When I went through reporting this to Microsoft, the recommended solutions said they are aware and working on this.
- Leenrem
Advocate I
Same problem here.
Sometimes it works, but often not.
- grazitti_sapna
Hi Schigia
Solution:
Solution:
Solution:
Solution:
Solution:
Let’s keep building smarter solutions together!- BrubakerM
Advocate I
This isn't a solution. These are workarounds at best. This appears to be a bug as the exact same PBI report doesn't have this problem in prior versions. Only the latest February 2025 version has a problem.
Version: 2.140.1205.0 64-bit (February 2025)
- dionisyNew Member
Upgrading to Version: 2.140.1476.0 64-bit (February 2025) worked for me.
Looks like bug was fixed there.
- Schigia
Advocate I
Thanks for your reply.. but in other files it is working.. only in some visuals is not. This from last friday. Before it was working and the data are the same. I will try to come back to previous version. Currently I have Feb 25
- Schigia
Advocate I
I think your point 5 is the concern. I used another pc with January version and the export data worked normally
- BrubakerM
Advocate I
We are getting reports from users having this issue. Started this week. Has always worked before. What hapens is after selecting export to CSV, the dialog box that normally pops up, asking where to save, doesn't pop up correctly. It comes up blank, sits for a while, then closes without doing anything.
- Leenrem
Advocate I
I have same problem. Started since the last Power BI update (feb 24th). Small exports work (about 5000 rows). But more rows not. When you try to download you see for a very short time a pop-up screen and after that nothing happens.... Is a update roll back possible?
- ravsaintRegular Visitor
Same here - 2 days ,but it desn't work in particular visualisation ( matrix data - rows, cols )
- TSHECKEL
Advocate II
We're experiencing this as well when exporting data from the desktop app. The "Working on it" window pops up for a second or two and then disappears. Version: 2.140.1205.0 64-bit (February 2025)
- PdatamanNew Member
I am having the same issue, I have a table I want to export that is ~30K rows and was able to export with no issues in the January release but in the Febuary release I either get the loading icon spinning then closing or Data Exceeds Limit.
