Error when using Power BI dataset as datasource - "Cannot load model"
- 6 years ago
I raised a MS ticket.
It turned out that user being on Windows 7 OS is the issue.
MS recommended to upgrade to Windows 10 OS and that should solve the issue it seems.
We are experiencing the same issue, the user is the owner and adm of the datasets,
the datasets are in the PBIService working properly and the reports as well.
.- The issue appears in PBI Desktop,. either for Reports pointing to PBI service loaded Datasets or new Data trying to get data from PBI datasets appears the same error "cant find, locate or you do not have permission to access to the dataset",
We need to solve it, pls, any suggestion is more than wellcome
