Error : While connecting to SQL DB Table using Power BI DirectQuery
- Anonymous5 years ago
Hi Anonymous ,
Based on my research, the error might occurs in the following possibilities:
1. An instance of the SQL Server Database Engine is not running.
2. The SQL Server Browser service is not running.
3. The TCP/IP is disabled.
4. The server name was typed incorrectly.
5. There are network problems.
6. The TCP/IP port for the Database Engine instance is blocked by a firewall.
7. The client and server are not configured to use the same network protocol.Then for the solutions, please refer to following articles:
https://blog.devoworx.net/2017/01/30/connection-timeout-expired-pre-login-handshake/
https://support.na.sage.com/selfservice/viewContent.do?externalId=83234&sliceId=1
https://www.kb.blackbaud.com.au/articles/Article/114624
Stephen Tao
Another option would be to build your report in Import mode, publish it to Power BI, and then build your reports with a live connection to the Power BI Dataset.
Pat
- Anonymous5 years agoNot applicable
We need to daily refresh and we have lot of dashboards, hence looking for Solution via DirectQuery.
