sanjaychandra's avatar
sanjaychandra
3 years ago
Drill Through Filters Pane Missing - Revised Pane - Power BI
I have enabled the new revised look of Power BI (where visual pane is inside the ribbon on the top). In the earlier version, I can drag & drop fields to create drill-through filters on my page and hide it.
Now I am trying to do the same with new revised pane. I am unable to figure out how to add drill through filters.
  • sanjaychandra , really tricky now . I keep on forgetting that. took sometime to find that.
    enable Format from view, if not visible and then use page type as - Drill Through
1 Reply
