6 years agoNot applicable
DISTINCTCOUNT values difference between AXIS visual and card visual
Hello, guys! I need some help over here, if you could so, I appreciate. I'm using a DISTINCTCOUNT to get the distinct values from column A applying this measure to a Card, but when I apply to a ...
- 6 years ago
Hi Anonymous ,
Here we go.
Measure 2 = VAR s = MAX ( Planilha1[Situação] ) VAR no = CALCULATETABLE ( VALUES ( Planilha1[Ordens] ), FILTER ( ALL ( Planilha1 ), Planilha1[Situação] <> s ) ) RETURN IF ( ISFILTERED ( Planilha1[Situação] ), CALCULATE ( DISTINCTCOUNT ( Planilha1[Ordens] ), FILTER ( Planilha1, NOT ( Planilha1[Ordens] IN no ) ) ), DISTINCTCOUNT ( Planilha1[Ordens] ) )Pbix as attached.
v-frfei-msft
6 years agoHi Anonymous ,
Here we go.
Measure = SUMX(VALUES(Planilha1[Situação]),CALCULATE(DISTINCTCOUNT(Planilha1[Ordens])))
Hi, v-frfei-msft
Thanks for your help! It's a good way too.
But I was trying to do the contrary.. apply the total of the first card (5,227) to the situation chart (when adding up all the situations, have 5,227 too).
How I said to az38
I don't even know if this will work fully.. but I wanna give a try before use a new dataset without these double orders.
(The original dataset came from my company and run by invoice and not by orders, so if I've to change it.. it'll take a while. And I don't wanna it).
