Anonymous's avatar
7 years ago
Display Values in same Column and Aggregate dynamically
Currently have a DimProducts table with the following columns: Accounting Class, Product ID.   Also, I have a DimOrder table with the following column: Cancellation Reason   I need to bring the c...
  • v-juanli-msft's avatar
    7 years ago
    Hi Anonymous
    I don't know how to calcuate the "Cancellations" value.
    So I make a test as "Cancellations"  is 5 by default.
    1.could you create a column in your table to define "Cancellations"=5? if not, please let me know.
    If you could, go on->
    2.create a column of the count of product id, if you have problem doing this, let me know.
    3.create columns
    remain = [count_product]-[cancellations]
    sub = SUM(DimProducts[cancellations])
    name = "Cancellations"
    4.finally create a new table
    Table 2 =
    UNION (
        SUMMARIZE ( DimProducts, DimProducts[Accounting], DimProducts[remain] ),
        SUMMARIZE ( DimProducts, DimProducts[name], DimProducts[sub] )
    If my formula doesn't work for your scenario, please share sone example datasets for me to test.
    ā€œ
    ā€œ
    Best regards,
    Maggie
