ingridg's avatar
ingridg
2 years ago
Display design vision problem
Hi, I want to do a report but I can't set up de information I want to put inside the graphics. I send a screenshot of what I see.
It is like I can't make the second column seem bigger.
Any help will be appreciated. thanks
  • ingridg's avatar
    ingridg
    2 years ago
    Hi!! thanks for the answer!
    Version: 2.115.842.0 64-bit (marzo de 2023)
    Operating system: windows.
    I just changed to mobile vision and then returned and it fixed! maybe It was an old set up that kept saved or something like that.
    Again, thanks for your answer!
    Ingrid
  • which version of Power BI Desktop?  What operating system?  What screen geometry?  Is it reproducible after a restart? Is it reproducible on another PC?
    • ingridg's avatar
      ingridg
      Ingrid
