Disable right click drill through when using button click drill through
I have a scenarion where the user needs the drill through to happen if it match the condition and to achieve this i have used button click drill thorugh which is working fine however for those rows which is not satisfying the condition and if i do the right click then also the drill through option is coming.
Can anyone please help if the right click can be removed / disabled or the right click drill through can only come if it matches the condition.
Subodh
- Kishore_KVN
Solution Sage
Hello Anonymous ,
If you create drill through page then all the visuals which are having matching with the drill through page will have that message of right click to do drill through and for few visuals it may not give complete information as per the selection so to create drill through only for the specific visual, create a duplicate of the column which is used for drill through and use that column only in the visual and also for the drill through creation. Then you still have that right click message but the advantage is data will be filtered here as per the selection.
If this post helps, then please consider accepting it as the solution to help other members find it more quickly. Thank You!!
- rubayatyasmin
Hi, Anonymous
try using bookmark.
- AnonymousNot applicable
Hi Kishore_KVN, thanks for the reply. Here i am using table card which has 10 rows and under one column there is some condition which need to be satified for enabling the drill through.
1. used button click drill through but right click drill drill through is also showing if i do the right click so i want restrict the right click from that particular table card.
2. condition based right click drill through if possible.
please let me know if any option can be feasible and if yes then how
