tangutoori
Helper III
3 years agoDifference between values in the same column between max and min dates
Dear Team, can you help me to solve the below scenario. INPUT Concatenate Part number Change Date Value 30Y0140,30Y01XY,30Y0160,30Y0ABC 30Y0140 05-01-23 10 30Y01...
- Anonymous3 years ago
Hi tangutoori ,
You can achieve it in Power Query Editor, please find the details in the attachment.
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("nY5LDoAgDAXvwpqEfgBxqV5CYrj/NSxUcWOMYdWhzMvrcRiGDOjBtrlnnVHfy7oZextCwaEjIBZEMMX+Tu9ZKI6mY+2eBtNK6UlTT2Ngr9ZFiG8l8kldq4T0esucZtduALi6ZVMVh9zL+UNXEt3fejClnA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Concatenate = _t, #"Part number" = _t, #"Change Date" = _t, Value = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Concatenate", type text}, {"Part number", type text}, {"Change Date", type date}, {"Value", Int64.Type}}), #"Grouped Rows" = Table.Group(#"Changed Type", {"Concatenate"}, {{"detail", each _, type table [Concatenate=nullable text, Part number=nullable text, Change Date=nullable text, Value=nullable number]}}), #"Added Custom" = Table.AddColumn(#"Grouped Rows", "Part numbers", each let min = List.Min([detail][Change Date]), max = List.Max([detail][Change Date]), result = if min=max then min else Text.From(min) & " & " & Text.From(max) in result), #"Added Custom1" = Table.AddColumn(#"Added Custom", "Dates", each let min = List.Min([detail][Change Date]), max = List.Max([detail][Change Date]), minpart = Table.SelectRows([detail],each [Change Date] = min)[Part number]{0}, maxpart = Table.SelectRows([detail],each [Change Date] = max)[Part number]{0}, result = if min = max then minpart else minpart & " & " & maxpart in result), #"Added Custom2" = Table.AddColumn(#"Added Custom1", "Delta", each let min = List.Min([detail][Change Date]), max = List.Max([detail][Change Date]), mindvalue = Table.SelectRows([detail],each [Change Date] = min)[Value]{0}, maxdvalue = Table.SelectRows([detail],each [Change Date] = max)[Value]{0}, result = if mindvalue = maxdvalue then mindvalue else Number.Abs(maxdvalue-mindvalue) in result), #"Removed Columns" = Table.RemoveColumns(#"Added Custom2",{"detail"}), #"Changed Type1" = Table.TransformColumnTypes(#"Removed Columns",{{"Part numbers", type text}, {"Dates", type text}, {"Delta", Int64.Type}}) in #"Changed Type1"Best Regards
3 years agoNot applicable
Hi tangutoori ,
result =
if min=max
then min
result),
result =
if
min = max
then minpart
else
result),
result =
if
then mindvalue
else
result),
#"Changed Type1"
