tangutoori's avatar
tangutoori
3 years ago
Difference between values in the same column between max and min dates
Dear Team,   can you help me to solve the below scenario.     INPUT       Concatenate Part number Change Date Value 30Y0140,30Y01XY,30Y0160,30Y0ABC 30Y0140 05-01-23 10 30Y01...
    3 years ago
    Hi tangutoori ,
    You can achieve it in Power Query Editor, please find the details in the attachment.
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("nY5LDoAgDAXvwpqEfgBxqV5CYrj/NSxUcWOMYdWhzMvrcRiGDOjBtrlnnVHfy7oZextCwaEjIBZEMMX+Tu9ZKI6mY+2eBtNK6UlTT2Ngr9ZFiG8l8kldq4T0esucZtduALi6ZVMVh9zL+UNXEt3fejClnA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Concatenate = _t, #"Part number" = _t, #"Change Date" = _t, Value = _t]),
        #"Changed Type" = Table.TransformColumnTypes(Source,{{"Concatenate", type text}, {"Part number", type text}, {"Change Date", type date}, {"Value", Int64.Type}}),
        #"Grouped Rows" = Table.Group(#"Changed Type", {"Concatenate"}, {{"detail", each _, type table [Concatenate=nullable text, Part number=nullable text, Change Date=nullable text, Value=nullable number]}}),
        #"Added Custom" = Table.AddColumn(#"Grouped Rows", "Part numbers", each let
    min = List.Min([detail][Change Date]),
    max = List.Max([detail][Change Date]),
    result =
    if min=max
    then min
    else Text.From(min) & " & " & Text.From(max)
    result),
        #"Added Custom1" = Table.AddColumn(#"Added Custom", "Dates", each let
    minpart = Table.SelectRows([detail],each [Change Date] = min)[Part number]{0},
    maxpart = Table.SelectRows([detail],each [Change Date] = max)[Part number]{0},
    result =
    if
    min = max
    then minpart
    else
    minpart & " & " & maxpart
    result),
        #"Added Custom2" = Table.AddColumn(#"Added Custom1", "Delta", each let
    mindvalue = Table.SelectRows([detail],each [Change Date] = min)[Value]{0},
    maxdvalue = Table.SelectRows([detail],each [Change Date] = max)[Value]{0},
    result =
    if
    mindvalue = maxdvalue
    then mindvalue
    else
    Number.Abs(maxdvalue-mindvalue)
    result),
        #"Removed Columns" = Table.RemoveColumns(#"Added Custom2",{"detail"}),
        #"Changed Type1" = Table.TransformColumnTypes(#"Removed Columns",{{"Part numbers", type text}, {"Dates", type text}, {"Delta", Int64.Type}})
        #"Changed Type1"
