Anonymous's avatar
4 years ago
Difference between values in a single column based on an identifying value
Hi there community!   I'm working with a dataset in which I'm trying to display on Customer and Article level the sales Amount. This is done by looking at a set of seperate Excel files all with the...
    4 years ago
    Hi Anonymous ,
    Please try:
    % (Customer level) =
    var _nextDate= MINX(FILTER(ALL('Table'),[Customer]=MAX('Table'[Customer])&& [File Date]>MAX('Table'[File Date])),[File Date])
    var _diff=CALCULATE(SUM('Table'[Amount]),FILTER(ALL('Table'), [Customer]=MAX('Table'[Customer]) &&[File Date]=_nextDate ))-SUM('Table'[Amount])
    return DIVIDE(_diff,SUM('Table'[Amount]))
    Or
    % (Article level) =
    var _nextDate= MINX(FILTER(ALL('Table'),[Customer]=MAX('Table'[Customer])&&[Article]=MAX('Table'[Article])  && [File Date]>MAX('Table'[File Date])),[File Date])
    var _nextSum=CALCULATE(SUM('Table'[Amount]),FILTER(ALL('Table'), [Customer]=MAX('Table'[Customer])&&[Article]=MAX('Table'[Article])&&[File Date]=_nextDate ))
    var _current=CALCULATE(SUM('Table'[Amount]),FILTER('Table', [Customer]=MAX('Table'[Customer])&&[Article]=MAX('Table'[Article])))
    return  DIVIDE( _nextSum-_current, _current)
    Eyelyn Qin
