difference between two values in same column
Year T otal Sales Difference in Sales from Last Year (should be result)
2014 0
2015 2.5 2.5
2016 4.5 2
2017 9 4.5
2018 0 -9
2019 2 2
How do you write dax for it?
Hi jiglow3501,
Please create the calculated column with the formula below.
Column =
VAR temp =
MAX ( 'table'[Total Sales] ),
FILTER ( 'table', 'table'[Year] = EARLIER ( 'table'[Year] ) - 1 )
IF ( 'Table'[Total sales] - temp = 0, BLANK (), 'Table'[Total sales] - temp )Then you will get the output below.
Cherry
- v-piga-msftResident Rockstar
Hi jiglow3501,
Column =
VAR temp =
Cherry
- AnonymousNot applicable
Hi v-piga-msft
I am working with a table with daily quantities.
What would be the formula for a calculated column with the daily difference of the quantities?
e.g.
Date Qty Diff
6/1/2020 1
6/2/2020 2 1
Thank you!
Daniel
