Daxtothemax
4 years agoHelper I
Difference between two values in same column
Looking for a way in Power BI to calculate the difference between values in the same column. Need the day over day change to the remaining duration based on example data below. Any help is greatly appreciated!
- CNENFRNLCommunity Champion
- DaxtothemaxHelper I
Wow, thank you so much!
Would you happen to know how to modify this formula to exclude an increase in duration and only base the change off the original duration?
Example:
Thank you again for the help.
