Difference between Rows of same Value Column for same ID using DAX
I'm struggling to transform the dataset below.
So basically I want to Calculate the difference group by ID
For instance:
Take the original value and subtract the value by the latest Modified date to get the difference.
From this
To this.
Any help would be appreciated.
Anonymous See my article on Mean Time Between Failure (MTBF) which uses EARLIER: http://community.powerbi.com/t5/Community-Blog/Mean-Time-Between-Failure-MTBF-and-Power-BI/ba-p/339586.
The basic pattern is:
Column =
VAR __Current = [Value]
VAR __PreviousDate = MAXX(FILTER('Table','Table'[Date] < EARLIER('Table'[Date])),[Date])
VAR __Previous = MAXX(FILTER('Table',[Date]=__PreviousDate),[Value])
__Current - __Previous
1 Reply
- Greg_DecklerCommunity Champion
Column =
