Difference between MIN and current value for filtered incremental values
- 6 years ago
Anonymous ,
Create a calculate column using dax below:
EnergyUsed = SWITCH(August[location.circuit], "total", August[data.energy] - 22000, "socket", August[data.energy] - 9900, "light", August[data.energy] - 2000)Community Support Team _ Jimmy Tao
Anonymous ,
Thanks v-yuta-msft for picking this up. (Original this post was refused, so I had to submit it again and got an answer, see here: https://community.powerbi.com/t5/Desktop/Difference-between-MIN-and-current-values-based-on-filter-of/m-p/831557#M399442)
However, your solution would work, too (so I'll mark it), but it would be quite labour intensive, i.e. every month when I download a new dataset, I would need to manually figure out the mininmum for each location.circuit....
