mario_ruiz's avatar
mario_ruiz
Helper II
4 years ago
Difference between Distinct and Unique when using column distribution
When using the Transform Data feature, over the View tab, there's an option that we can check: Column distribution, which brings distinct and unique values... What's the difference between these values? By Distinct values can I assume there are duplicates of the same value and for unique there are no duplicates? I already went into the documentation but it still is not clear. Thanks.
https://docs.microsoft.com/en-us/power-query/data-profiling-tools
  • MahyarTF's avatar
    MahyarTF
    Memorable Member
    Distinct mean : count all the values as 1, even if there was more than one.
    Unique mean : count only the value that are not repeated in the particular column
    Appreciate your Kudos
  • HoangHugo's avatar
    HoangHugo
    Solution Specialist
    I found it from Online
    “Distinct” means total number of different values regardless how many times it appears in the dataset. A name appears in the list multiple times is counted as 1 distinct count.
    Whereas, the “Unique” value is total number of values that only appear once.
  • stumit's avatar
    stumit
    A good question given that the link that mario_ruiz's description of the "definitive" MicroDoc he linked to falls short.
    The page https://docs.microsoft.com/en-us/power-query/data-profiling-tools mentions the terms 'Distinct' and 'Unique' but provides no definition.
    MahyarTF and HoangHugo describe it perfectly.
    I did a test to see the facts. Findings below the image, some interesting.
    Distinct is the count of distinct values as in SQL:
    Select count(distinct colname)
    from tablename;
    Unique is equivalent of:
    with uniq(ResellerKey, cnt)
    as
    select ResellerKey, count(*) as cnt
    from FactResellerSales
    group by ResellerKey
    having count(*) = 1
    select count(*)
    from uniq
    Enough of the SQL.
    This image demonstrates the results. From Excel, the blanks showed null. From CSV with consecutive commas it showed blank. Rather than two images I change the null to blank in the 4th column of the Excel load.
    It is clear that null and blank are counted in Distinct. Multiple null/blank did not make it into Unique. Simple image for you to count yourself to full understand.
    UPDATED IMAGE: I put a blank in No Duplicates to show that blank/null can be considered Distinct.
    Interestingly, I had to close PBI Desktop to update the Empty to 7% in No Duplicates column. Refresh didn't do it. Neither did Apply and Close and then Transform. The profiling must be cached.
