Difference between dates using two tables
Hi ChinoZambrano93 ,
It‘s not very clear to me since your second screenshot is too small. Would you please show us some sample data and your expected output. Then we will help you well.
Dedmon Dai
Thank you for your response @v-deddai1-msft , attached more images about visualizations, tables and model.
It's two boards,
1. Catalogue of Works, where I have the following fields: Rubro(Task), Start Date, End Date, Duration and Daily Value.
2. Date Table
Both tables are related by the Date and Start Date fields, an active one-to-many relationship.
The result I need is an array where the Rows field has the Rubro field, the columns in the Date field, and in the Value field a measure that allows me to place the daily values between the start and end dates of each item.
Please help...
- v-deddai1-msft6 years agoCommunity Support
Just show us some sample data and your expected output by onedrive for business. I still can't see your screenshots since they are too small.
Dedmon Dai
- ChinoZambrano936 years agoRegular Visitor
I'm sending you an example I did in excel. Maybe this will better understand my problem.
https://drive.google.com/file/d/1dm4H2rAdU1k6Ho4hAopL6t0u3NQoIHtW/view?usp=sharing
Best regards
Help, I'm still stuck with this problem
