difference between data _ months in same column
- 4 years ago
Hi Cynthia. In order for this to work, you need to do three things first:
- Make sure your data model has a date table and that it is marked as one
- Convert your values of "Jan 21", "oct 21", etc. to actual date values. Go with month ending values.
- Create a relationship between the date field in the date table and the date field in your data.
After you do those things, create measures like the following
Current Month = SUM([Value]) Prior Month = CALCULATE( [Current Month] PREVIOUSMONTH([Use the name of the date column from the date table]) ) MTM Difference = [Current Month] - [Prior Month]Hope this helps!
- 4 years ago
Hi Cynthia
I created the solution for you. Follow the logic in the attached pbix. Let me know if you have any questions. 🙂
Hi Cynthia ,
According to your description, refer to the following formula. If you don't want to categorize the item column, just delete 'Table'[Category] = EARLIER ( 'Table'[Category] ) from the formula.
Col_ =
VAR current_ =
MAX ( 'Table'[Date] )
VAR next_ =
MAX ( 'Table'[Value] ),
FILTER (
ALL ( 'Table' ),
'Table'[Date] > EARLIER ( 'Table'[Date] )
&& 'Table'[Category] = EARLIER ( 'Table'[Category] )
next_ - 'Table'[Value]
Also note that the data field needs to be changed to a date type.
If the problem is still not resolved, please point it out. Looking forward to your reply.
Henry
Hi v-henryk-mstf ,
first, thank you so much for support and patience. I am not sure what was the issue, but when replacing the data it was still not leading to the results needed. Maybe I did something wrong. Maybe it is also related to the hierarchy levels that I have in category. I am a beginner, so I am not really sure. The proposal from user littlemojopuppy using measures worked. So I have accepted as solution.
Again, thank you very very much.
Kind regards,
Cynthia
