POSPOS's avatar
POSPOS
Icon for Post Partisan rankPost Partisan
2 years ago
Days between dates of same column using DAX
Hi All,
I have a requirement to find the days between dates of the same column.
The first value should be the difference between the date and the date of the next step and the last value should be zero.
I have attached a sample pbix file with date here.
Could someone please suggest on how to achieve this using DAX.
    2 years ago
    Hi POSPOS ,
    Please try:
    Column =
    VAR _cur_protocol = 'export'[Protocol Number]
    VAR _cur_index = 'export'[Index]
    VAR _next_index = CALCULATE(MIN('export'[Index]),FILTER(ALL('export'),'export'[Protocol Number]=_cur_protocol && 'export'[Index]>_cur_index))
    VAR _next_date = CALCULATE(MIN('export'[Status Date]),ALLEXCEPT('export','export'[Index]),'export'[Index]=_next_index)
    VAR _result = COALESCE(DATEDIFF('export'[Status Date],_next_date,DAY),0)
    _result
    Gao
    Community Support Team
    If there is any post helps, then please consider Accept it as the solution  to help the other members find it more quickly.
    If I misunderstand your needs or you still have problems on it, please feel free to let us know. Thanks a lot!
    How to get your questions answered quickly --  How to provide sample data in the Power BI Forum -- China Power BI User Group
  • DaysTillNextSatus=
    VAR CurrentStatusDate = Min('export'[Status Date])
    VAR CurrentProtocol = SELECTEDVALUE('export'[Protocol Number])
    var NextDate = CALCULATE(
        Min('export'[Status Date]),
        FILTER(
            ALL('export'),
            'export'[Status Date] > CurrentStatusDate && CurrentProtocol = 'export'[Protocol Number]
    VAR vDifference = DATEDIFF(CurrentStatusDate , NextDate, DAY)
    RETURN if(ISBLANK(vDifference), 0, vDifference)
    • POSPOS's avatar
      POSPOS
      Data-estDog  - thank for the response.
      When the dates are same, the values are not showing as expected. In this example, "Staff" comes before "Assigning", hence staff should be 9 and Assigning should be 0.
      But 9 is repeated for both the statuses.
      • Data-estDog's avatar
        Data-estDog
        Icon for Resolver II rankResolver II
        You would need a more granular date/time stamp. Or a sequence number (order the status was changed in) in order to achieve that.
