elaj
Helper IV
6 years agoDAX to create a sort column without having ring dependency problem
Hi guys, i try to sort a column by a DAX calculated column wich references the column wich i want to sort. therefore i get a ring dependency problem. My workaround would be to copy the colum...
6 years agoNot applicable
Hi elaj,
I think this dependency issue is caused by using the raw field in other fields calculated and invoke this calculated field on raw field operations. (if you keep this scenario, I don't think you can prevent dependency issue appears)
Perhaps you can try to create a new table to extract these fields(use all to extract) and apply custom sorting on new table and link to raw table fields to enable custom sorting.
BTW, you can take a look at below blog to know more about circular dependency issue:
Avoiding circular dependency errors in DAX
Xiaoxin Sheng
