3 years agoNot applicable
Dax Help to split years between two dates using Dax or Power Query
Hi Experts , How can I split years between two dates using Dax or Power Query
| Start Date | End Date | Output |
| 01-01-2021 | 01-01-2023 | 2021, 2022, 2023 |
1 Reply
- AmiraBedh
Using Power Query :
let SplitYears = (StartDate, EndDate) => let StartYear = Date.Year(StartDate), EndYear = Date.Year(EndDate), ListYears = {StartYear..EndYear}, Result = Table.FromList(ListYears, Splitter.SplitByNothing()) in Result in SplitYearsNow you can use this function in your main query :
SpoilerSplitYears([Start Date],[End Date])Using DAX :
You can create a calculated table with the following DAX formula:
YearTable = ADDCOLUMNS( CALENDAR( YEAR(MIN(Table[Start Date])), YEAR(MAX(Table[End Date])) ), "Year", YEAR([Date]) )Then create a calculated column in your main table that concatenates the years for each row. You could use the CONCATENATEX function to do this :
YearList = CALCULATE( CONCATENATEX( YearTable, YearTable[Year], ", " ), YearTable[Year] >= YEAR(Table[Start Date]), YearTable[Year] <= YEAR(Table[End Date]) )
