Anonymous's avatar
8 years ago
Dax Help - Work out custom days between
I have a calendar table with the following fields
Date      |         Index
I then have a table called Holidays with the fields
From     |        To
There are inactive relationships between the from and to in the holiday table to the date field in the calendar table.
How would I go about calculateing the days between using the index field for 'to' - index field from'from'.
  • Hi Anonymous,
    What does your data look like? Please check out the demo in the attachment.
    It could be a calculated column like this.
    days =
        SUM ( 'Calendar'[Index] ),
        FILTER ( 'Calendar', 'Calendar'[Date] >= [From] && 'Calendar'[Date] <= [To] )
    Dale
  • anandav's avatar
    anandav
    Icon for Skilled Sharer rankSkilled Sharer
    HI Anonymous,
    Have you tried creating a new column in Holiday table?:
    Column = DATEDIFF(Table3[From], Table3[To], DAY)
    Or a measure:
    Measure = DATEDIFF(MIN(Table3[Column1]), MIN(Table3[Column2]),DAY)
      Hi Anand,
      I wont be able to use that as I need to exclude weekends ands bank holidays.
      • v-jiascu-msft's avatar
        v-jiascu-msft
        Hi Anonymous,
        days =
        Dale
