5 years agoNot applicable
Amit,
The first issue I see is that I cannot use Blanks as I have many records that are actually blank and I need to exclude these. I need this to work only when the value is == 0. The second is that I wish to use this measure as a slicer.. as in True or False. I do like your example. Thank you.
5 years agoSuper User
Anonymous , you can try like
Rolling 3 =
var _1= CALCULATE(sum(Sales[Sales Amount]),DATESINPERIOD('Date'[Date ],eomonth(MAX('Date'[Date]),0),-3,MONTH))+0
return
if(_1 =0 , 1, 0)
