Date/Time Issue between SQL and Power BI Desktop
- 6 years ago
Hi eliassal ,
Becasue date type in sql server is corresponded with date/time type in power bi desktop.
If you want to use horizontal bar chart to show the date without time, I think you should contact the owner of this custom visual because this custom visual shows time automatically and we could not change it settings.
One temporary way to use this visual to show date without time is to change the data type in cast() function from date to varchar:
Or you can use default bar charts in power bi such as Stacked bar chart, change the format of daily field and change the type of Y-axis as Categorical:
Yingjie LiIf this post helps then please consider Accept it as the solution to help the other members find it more quickly.
Li, you are showing the same thing which I want to get rid of the time in the 1st column
The initial question, why Power BI adding time by iteself?
Hi eliassal ,
Yingjie Li
- eliassal6 years ago
Helper II
The owner is MDS corporation 😂 thanks for the tips, I have already started to use the stacked bar chart but the other visual is much nicer for visualization
