DateFormat Error in Power BI using Sharepoint connection
Hi msft-cap
One of the columns defined as Date/Time likely contains values with inconsistent or invalid formatting, which causes Power BI to throw a [DataFormat.Error] when trying to parse them.
This usually happens when:
The column includes values with leading/trailing spaces (e.g.,
" 01/02/2024"). -
The date format in the source file differs from the expected format in Power BI (e.g., U.S.
MM/DD/YYYYvs. U.K.DD/MM/YYYY). -
Some values are not valid dates at all.
You have two options to resolve this:
Fix the source file – If possible, open the SharePoint file and clean up the problematic column by removing extra spaces and making sure the date format is consistent.
Handle it in Power BI – In Power Query:
Use
Text.Trim()before converting the column to date. -
Use Using Locale when converting to date to match the original date format (e.g., English (United States) or English (United Kingdom)).
If this post helps, then please consider Accepting it as the solution to help the other members find it more quickly
