Date Difference between two values in the same column with same Id
- 5 years ago
Hi, WorkHard
You can create a column to calculate the dasired result.
Like this:
column = VAR a = MAXX ( FILTER ( ALL ( 'Table' ), [-Snapshot Date-] < EARLIER( 'Table'[-Snapshot Date-] ) && [-EventId-] = EARLIER( 'Table'[-EventId-] ) ), [-Snapshot Date-] ) VAR b = MAXX ( FILTER ( ALL ( 'Table' ), [-Snapshot Date-] = a && [-EventId-] = EARLIER( 'Table'[-EventId-] ) ), [-StartDate-] ) RETURN DATEDIFF ( b, 'Table'[-StartDate-] , DAY )If it doesn’t solve your problem, please feel free to ask me.
Janey Guo
- WorkHard5 years ago
Helper V
Thanks. I was hoping for a DAX formula but I'll try to do this in Power Query, like you did.
What if I want to calculate the Start Date in relation to the previous snapshot date?
Check OP for an example.- Ashish_Mathur5 years ago
You are welcome. How did you arrive at the numbers in the Desired result column of the second table in your original post? I am not clear.
Helper V
Hi Ashish_Mathur ,
The 3 rows for Event1 come from different points in time. I take a "snapshot" of the data once a month and then every month I add another row for the same event. So over time, the Start Date of the event can change. This gives me the ability to see how the start date for the same event changes every month.
The Start Date for Event1 in the snapshot from January 2021 was January 15.The Start Date for Event 1 in the snapshot from February 2021 was March 17 (61 days).
The Start Date for Event 1 in the snapshot from March 2021 was March 15 (-2 days)
The Start Date for Event 2 in the snapshot from January 2021 was March 1.
The Start Date for Event 2 in the snapshot from March 2021 was February 1. (+28 days)
