Anonymous's avatar
2 years ago
Date calculation problem, need help
How would I solve the following?
"Anniversary",  "Date Pulled" and "Tenure Years" are "Columns" in my table
I  will also be needing "Todays date"
I believe I need to write a  dax measure to correctly find the correct answer  as "Todays  Date" will change based on when the user accesses the power bi dashboard.   If I used a column to contain  "Todays Date", it  would always stay the same to the date and time it was published if I understand correctly.
Here is what I am trying to do:
If "Anniversary" > "Date Pulled" and < "Todays Date"
then Tenure Years + 1 else Tenure Years
Is there an easy answer for this ?  Thank you for any help
