Datatype is not same while importing from SQL Server with direct query in power BI desktop
Hi Krishna1992,
I can't reproduce this issue.(I test with sql 2016) Which version of sql and power bi desktop you test? If you switch import mode, did this issue appears?
Xiaoxin Sheng
- Krishna19928 years ago
Hi Anonymous,
Used sql server 2012 and latest powerbi desktop.
In sql server 2012, added the tables and performed query to change the datatype. Meanwhile when I tried to import it into the powerbi desktop changed datatype (query which I performed doesnt take effect).
In import mode also same datatype is appearing but in import mode we can change the datatype.
But my issue is I need this in direct query only.
Please let me know if anything possible, do I need to change something in sql server.
Thanks.
- Anonymous8 years agoNot applicable
Hi Krishna1992,
It seems like you change column type after get data to power bi. If you create new report with same data source, did this data type issue appears again?
If data type issue fixed on new report, I'd like to suggest you save your direct query mode report as template.
After these steps, you can try to use template file to generate new report with same datasource to see if data type issue fixed.
Deep Dive into Query Parameters and Power BI Templates
Xiaoxin Sheng
Hi Anonymous,
I have converted in sql server and imported into the power bi.
No Issues thanks for the comment.
