Anonymous's avatar
7 years ago
Data package using Power Query in Power BI
Let me know the use of data package . Also the code for the data package using Power Query(Advanced editor) in Power BI in which the data is .json/.csv format (prefered Frictionless data).
#DataPackageHelper #DataPackageTable #DataPackageTables
  • Hi Anonymous,
    We've done a bug fix release this morning which includes a fix for an issue that would have affected your use of the mentioned data packages. We've also provided a workaround for a known bug which we are working with the Power BI support team to resolve.
    Please follow the setup steps to get the latest versions of the functions into a Power BI file. Once this has been done, you can use the following Power Query expressions to create two new queries: one for the Air Quality data package and another for the Pharmaceutical Drug Spending by countries data package:
    A query that returns data from the 'monthly-averages' resource/data file in the Air Quality data package:
        data = DataPackageTable("https://datahub.io/core/london-air-quality", null, "monthly-averages")
        data
    A query that returns data from the 'data' resource/data file in the Pharmaceutical Drug Spending by countries data package:
        data = DataPackageTable("https://datahub.io/core/pharmaceutical-drug-spending", null, "data")
        data
    Hope this helps.
    Michael
  • v-jiascu-msft's avatar
    v-jiascu-msft
    Hi Anonymous ,
    Could you please make it more clear what the Data Package it is? I suppose you mean the service-dataflows-overview. So what kind of code would you like?
      • michaelamadi's avatar
        michaelamadi
        Hi Anonymous,
            data
            data
        Hope this helps.
        Michael
