dasingh9's avatar
dasingh9
8 years ago
Data Modeling for Power BI using Raw Data
Hi, In the current scenaio, I have two tables (WORKSHOPS_TABLE, APPOINTMENTS_TABLE) in the data warehouse (see attached screenshot). In each table, Faculty column may contain multiple values like "A...
  • Ashish_Mathur's avatar
    8 years ago
    In the Query Editor window of PBI desktop, right click on the second column of the Workshops_Table and go to Split > Split b delimiters > Specify , as a seperator.  Under Advanced, select rows.
    Hope this helps.
  • v-piga-msft's avatar
    8 years ago
    Hi dasingh9,
    You could prepare your data model in Query Editor. Assuminng that you have two tables (WORKSHOPS_TABLE, APPOINTMENTS_TABLE).
    1. Go to Query Editor
    2. select one table then select the column Faculty to Split column by Delimiter
    3. select columns Faculty.1 and Faculty.2 with Ctrl and click Unpivoted Columns
    4. Rename the Value to Faculty
    5. Remove the column Attribute
    6. do the same option for another table
    7. Close and Apply
    Then you could create the chart below.
    For reference, you could have a look at my test pbix file attached below.
    Cherry
