Currency conversion issue Sumx Issue
Hello jdbuchanan71 , but the rule of conversion is different.
The rule or the formula of calulation is like:
Sales(Euro) = calculate( divide(YTD Sales Month; Exchange rate Month) - Divide( YTD Sales Month - 1 ; Exchange rate Month -1))
Exampl for Sales (Euro)of February= calculate(Divide( YTD Sales february ; Exchange rate February) - Divide( YTD Sales Janyary ; Exchange Rate January))
Not sure I am following your example formulas. Given your sample data, could you fill in the last 2 columns in this table?
| Country | Date | Sales Amount | Value | Expected_Result | Formula |
| RUSSIA | 1/1/2019 | 28,325,732 | 76.3054545 | ||
| RUSSIA | 2/1/2019 | 10,624,860 | 75.5497 | ||
| RUSSIA | 3/1/2019 | 24,620,460 | 74.9093921 | ||
| RUSSIA | 4/1/2019 | 15,480,003 | |||
| RUSSIA | 5/1/2019 | 3,880,002 | |||
| RUSSIA | 6/1/2019 | 6,480,002 | |||
| RUSSIA | 7/1/2019 | 6,480,002 | |||
| RUSSIA | 8/1/2019 | 10,480,002 | |||
| RUSSIA | 9/1/2019 | 16,880,002 | |||
| RUSSIA | 10/1/2019 | 1,800,002 | |||
| RUSSIA | 11/1/2019 | 1,800,002 | |||
| RUSSIA | 12/1/2019 | 19,306,110 |
- dkozak7 years agoFrequent Visitor
- d_gosbell7 years ago
I think your expected result is incorrect.
Mathematically "YTD Feb" = (Jan Sales + Feb Sales). So doing "YTD Feb" / "Feb Rate" is the same as:
Jan Sales / Feb Rate
+ Feb Sales / Feb Rateso you are doing:
+ Feb Sales / Feb Rate- Jan Sales / Jan Rate
Which is applying both Jan and Feb rates to the Jan Sales. I cannot see logically how this could be valid.
The original approach suggested by jdbuchanan71 is the typical pattern that would be used in a currency conversion situation. I don't think you can use the RELATED() pattern as you need to look up the rate for a period and country, but you could use a LOOKUPVALUE() expression instead to achieve this.
Expected values are goods ( columns D, E are precalculated for example: YTD Sales for Djaber country in february equals 3000=[ January 1000 + February 2000])
For the formula i can't do anything. Its imposed ;( , i'll gonna be crazy
To precise the problem or the issue: the problem is that i can't use ytd of previous period inside sumx()
Any one have a suggestion.
jdbuchanan71 The caption was for sales of february
