Currency conversion issue Sumx Issue
Hello dkozak
You already have the relationship between Sales and Rates Table using Key-Link-Sales so your measure can just use that.
Sales Amount € = SUMX ( Sales, Sales[Sales Value] * RELATED ( 'Rates Table'[Value] ) )
Hello jdbuchanan71 , but the rule of conversion is different.
The rule or the formula of calulation is like:
Sales(Euro) = calculate( divide(YTD Sales Month; Exchange rate Month) - Divide( YTD Sales Month - 1 ; Exchange rate Month -1))
Exampl for Sales (Euro)of February= calculate(Divide( YTD Sales february ; Exchange rate February) - Divide( YTD Sales Janyary ; Exchange Rate January))
- jdbuchanan717 years ago
Not sure I am following your example formulas. Given your sample data, could you fill in the last 2 columns in this table?
Country Date Sales Amount Value Expected_Result Formula RUSSIA 1/1/2019 28,325,732 76.3054545 RUSSIA 2/1/2019 10,624,860 75.5497 RUSSIA 3/1/2019 24,620,460 74.9093921 RUSSIA 4/1/2019 15,480,003 RUSSIA 5/1/2019 3,880,002 RUSSIA 6/1/2019 6,480,002 RUSSIA 7/1/2019 6,480,002 RUSSIA 8/1/2019 10,480,002 RUSSIA 9/1/2019 16,880,002 RUSSIA 10/1/2019 1,800,002 RUSSIA 11/1/2019 1,800,002 RUSSIA 12/1/2019 19,306,110 - dkozak7 years agoFrequent Visitor
- d_gosbell7 years ago
I think your expected result is incorrect.
Mathematically "YTD Feb" = (Jan Sales + Feb Sales). So doing "YTD Feb" / "Feb Rate" is the same as:
Jan Sales / Feb Rate
+ Feb Sales / Feb Rateso you are doing:
+ Feb Sales / Feb Rate- Jan Sales / Jan Rate
Which is applying both Jan and Feb rates to the Jan Sales. I cannot see logically how this could be valid.
The original approach suggested by jdbuchanan71 is the typical pattern that would be used in a currency conversion situation. I don't think you can use the RELATED() pattern as you need to look up the rate for a period and country, but you could use a LOOKUPVALUE() expression instead to achieve this.
jdbuchanan71 The caption was for sales of february
