Hassanz
3 years agoFrequent Visitor
Creating Connection is Model - Power BI Desktop
Hi everyone,
I have been getting to see 'Creating Connection to Model' which is never ending while loading data to my model. I have changed the datasource from Web to an SQL based database. If I get the data using the Web link, it works fine. However, if I try to get data using SQL database, it just keep on trying to create connection.
Is there a quick fix for this?
I would really appreacite your help!
Regards
- jdbuchanan71
In the options, try turning off the connections features in your file.
- HassanzFrequent Visitor
Hi jdbuchanan71
Thank you for your suggestion.
I have applied these settings, but nothing changed.
