7 years agoNot applicable
Create Non Numeric (String) measure using IF and ELSE condition
Something like DATA = If(TableA= "ABCD", "LARGE", "SMALL") I need to create this as a measure because i need to use it in another measure which where i will be using this XYZ and another number cond...
reza_rad
Advocate IV
7 years agoA table cannot be equal to a text value. In DAX, you cannot say TableA="ABCD". If you want a cell value to be equal to that, you have to mention the column name, and also filter the rows to get to the row that you want. Or alternatively, you have to use functions that search the entire column, such as Contains.
Sorry it should have been MeasureName = If(Table(ColumnA)= "ABCD", "LARGE", "SMALL")
- v-jiascu-msft7 years ago
Hi Anonymous,
You can simply add "min" or "max" to the column. Please refer to the snapshot below. BTW, a measure needs the context in the visual.
MeasureName = IF ( MIN ( Table1[ColumnA] ) = "ABCD", "LARGE", "SMALL" )
Dale- Anonymous7 years agoNot applicable
Thanks for the reply.. I was able to create the measure with the "min" function on Friday, Appreciate your response.
