Connection Problem - set 'sslmode' as 'require' in connection settings
Hi Miguel_Rojo
We are following up to see if your query has been resolved. Should you have identified a solution, we kindly request you to share it with the community to assist others facing similar issues.
If our response was helpful, please mark it as the accepted solution and provide kudos, as this helps the broader community.
Thank You!
- Miguel_Rojo1 year ago
Helper II
Hi v-karpurapud ,
Thanks for the follow up.
The issue has not been resolved.
As suggested in past threads, I made the next actions trying to fix it:
- install postgrsql drivers on windows for odbc powerbi
- Use Full Server Name & Port
- Clear Cache & Re-enter Credentials
I continue with a workaround for this issue (use Dataflow instead "local Power Query").
But I think that i'll need to contact the Adobe team support to address this issue.
Miguel
- v-karpurapud1 year ago
Hi Miguel_Rojo
Reaching out to Adobe's support team is the best way to address this. They have the expertise to help you resolve the issue quickly and efficiently.
Thank You!
