Connecting QuickBooks (Beta) to Power BI Dashboard - Script Errors
Good afternoon,
I have been looking through the community and noticed some posts addressing using the 'Get Data' to connect QuickBooks data with Power BI. Upon doing so, I am continuously getting Script Errors when attempting to use my login credentials to link my QBO account. Are admin credentials required to connect the data for both Power BI and QBO, or just one or the other? I am looking to get started creating models and am curious as to what the solution is to fix this problem.
Thank you in advance to anyone that can lend some assistance!
Hi, geradgreco
This issue is listed in Support site, you can keep an eye on the status of it:
As a short term mitigation, the Intuit team has rolled back the impacting change for two weeks. During this time, customers are requested to log in using the Power BI desktop client and then refresh their report every 30 days until a permanent fix is available.
The long-term solution to this issue is expected to be deployed by the end of March 2021.
Community Support Team _ Eason
- vanessafvg
i think you need to be admin on the quickbooks side.
- geradgrecoNew Member
Thank you for notifying me of this vanessafvg! I am going to go ahead and try this out.
- v-easonf-msft
Hi, geradgreco
Could you please tell me if your problem has been solved? If it is, please mark the helpful replies as Answered.
Other community members will easily find the solution when they get the same issue.Best Regards,
Community Support Team _ Eason- geradgrecoNew Member
I have not had any luck yet with this new implementation to connect the QBO account to Power BI. Sorry!
- v-easonf-msft
Hi, geradgreco
Community Support Team _ Eason- syntrixsystemsFrequent Visitor
Hi, do you have a status on this issue? The 'support site' link you noted is broken and doesn't work. I'm getting a string of script errors leading to a blank window (first time user of this connector).
Thank you for this! I greatly appreciate it!
Any updates on this? First time trying to connect to QBO but receiving tonnes of script errors. Is there any work around if this is the first time connecting?
- v-easonf-msft
Hi , syntrixsystems
Please check it here.
https://powerbi.microsoft.com/en-us/support/
If this post helps, then please consider Accept it as the solution to help the other members find it more quickly.- syntrixsystemsFrequent Visitor
You keep linking to the general support site, do you have a specific open issue you can link for this?
- EugeneLebedev
Helper V
I would recommend this solution: https://azuremarketplace.microsoft.com/en-us/marketplace/apps/vidicorpltd1717496723264.qbo-powerbi-connector
You essentially get your connector with data conveniently aggregated into tables like P&L, Balance Sheet, Cash flow, etc. You also get a set of Power BI reports for P&L, Balance Sheet, Cash Flow and Accounts receivables as a PBIX file.
