Connecting Power BI with SQL database
Have you looked at the Dynamics 365 'Data Export' solution?
It replicates the data from the CRM to an Azure SQL Database and keeps it synchronised.
We have been using this for various analytics scenarios on Dynamics 365 data.
Matt
Anonymous I just recently got the DES, haven't really tried yet. do you know how's the speed compare to DES to Power BI and Dynamic CRM to Power BI?
- Anonymous9 years agoNot applicable
Hi Anonymous,
In my experience the initial replication of the CRM can take some time, depending of course of the amount of data in there, but once it's up and running you can play around with the different service levels of the Azure SQL Database - the P1 service tier is the minimum recommended to avoid any issues with throttling during the replication and synchronisation, and you can always increase it depending on what you are doing.
Having said that, I have seen issues whereby we have increased significantly the service tier of the database, but a refresh in Power BI still takes a while and doesn't use up all the DTUs (i.e. not maxing out the performance of the service tier).
Main advantage is that you can query away without impacting the Production environment, as Anonymous mentions.
Matt
