Anonymous's avatar
1 year ago
Connect AWS S3 with Power BI using Python
Hi Team,
I’m looking to connect AWS S3 with Power BI using Python, and I need some guidance on how to achieve this.
If anyone has experience or can share a step-by-step solution, I’d really appreciate your help. This is quite urgent for my current project.
Looking forward to your suggestions.
Thanks in advance!
  • Anonymous
    You’ll need to use boto3 to connect to your S3 bucket.
    import boto3
    import pandas as pd
    from io import StringIO # or BytesIO for binary files like Excel
    # Set up AWS credentials (ideally, use IAM roles or environment variables)
    aws_access_key = "YOUR_ACCESS_KEY"
    aws_secret_key = "YOUR_SECRET_KEY"
    bucket_name = "your-bucket-name"
    file_key = "folder/yourfile.csv" # S3 object key (path)
    # Connect to S3
    s3 = boto3.client('s3', aws_access_key_id=aws_access_key,
    aws_secret_access_key=aws_secret_key)
    # Get the file object
    response = s3.get_object(Bucket=bucket_name, Key=file_key)
    data = response['Body'].read().decode('utf-8') # for CSV
    # Load to pandas
    df = pd.read_csv(StringIO(data))
    print(df.head())
    Did I answer your question? Mark my post as a solution! Appreciate your Kudos !!
  • Anonymous
    import boto3
    import pandas as pd
    # Connect to S3
    # Load to pandas
    print(df.head())
  • v-ssriganesh's avatar
    v-ssriganesh
    Hi Anonymous,
    Thank you for reaching out to the Microsoft Fabric Community Forum.
    The solution shared by johnbasha33is spot-on for connecting AWS S3 to Power BI using Python.
    If this information is helpful, please “Accept it as a solution” and give a "kudos" to assist other community members in resolving similar issues more efficiently.
      v-ssriganesh
      Hi Anonymous,
      I hope this information is helpful. Please let me know if you have any further questions or if you'd like to discuss this further. If this answers your question, please accept it as a solution and give it a 'Kudos' so other community members with similar problems can find a solution faster.
    v-ssriganesh
    Hi Anonymous,
    v-ssriganesh
    Hi Anonymous,
