Conditional formatting for multiple columns issue - Need Help
Hi Community,
I am new to Power BI. Some one please provide me a solution for the following issue.
I have a double heading matrix where customers are in Rows, two columns Status and Description are in the columns section (Both columns are from same lookup table), and a measure in the values section which will display the distinct count in the matrix. Following is the DAX.
DistinctRoster:= IF(CALCULATE(DISTINCTCOUNT(FactStatus[RosterId])) = BLANK(), 0, CALCULATE(DISTINCTCOUNT(FactStatus[RosterId])))
The matrix is like
Issue: I have to implement background color for column Active placements based on column Placed Duration in Fact table and for column Pending based on column Pending Duration in fact table.
I added background color for column Active Placements by going to conditional formatting --> Format By rules--> and BAsed on field. It worked great for that column.
But how i can implement the background color for column Pending? I got stuck at this point.
TIA.
Anonymous , In a matrix you should be able to define a rule for all the columns.
You can create a color measure and use that with "Field" Option
color = switch ( true(), FIRSTNONBLANK(Table[commodity],"NA") ="commodity1" && sum(Table[Value]) >500,"lightgreen", FIRSTNONBLANK(Table[commodity],"NA") ="commodity2" && sum(Table[Value]) >1000,"lightgreen", /// Add more conditions "red" )Color Field - Color Measure - Conditional formatting
https://radacad.com/dax-and-conditional-formatting-better-together-find-the-biggest-and-smallest-numbers-in-the-column
https://docs.microsoft.com/en-us/power-bi/desktop-conditional-table-formatting#color-by-color-values
https://exceleratorbi.com.au/conditional-formatting-using-icons-in-power-bi/
https://community.powerbi.com/t5/Desktop/FORMAT-icon-set-for-use-in-a-data-card/td-p/811692Hi Anonymous ,
Create a measure like this, choose Field value in the conditonal format page, apply it on the background of the previous measure:
color = SWITCH( TRUE(), SELECTEDVALUE('Table'[Group]) = "A" && 'Table'[test] >=1 && 'Table'[test] <=15, "#1E90FF", SELECTEDVALUE('Table'[Group]) = "B" && 'Table'[test] >=1 && 'Table'[test] <=30, "#00FA9A", SELECTEDVALUE('Table'[Group]) = "C" && 'Table'[test] >=1 && 'Table'[test] <=45, "#8A2BE2", "#FF0000" )Attached a sample file that hopes to help you: conditional format.pbix
Yingjie LiIf this post helps then please consider Accept it as the solution to help the other members find it more quickly.
- amitchandak
https://community.powerbi.com/t5/Desktop/FORMAT-icon-set-for-use-in-a-data-card/td-p/811692 - v-yingjl
Hi Anonymous ,
