POSPOS's avatar
POSPOS
Icon for Post Partisan rankPost Partisan
3 years ago
Conditional columns using DAX in Power BI
HI All,
I have a requirement to display a new column based on a two other columns from the same table.
Scenario:
For each contract no., look for the minimum 'contract received date' and then display the respective 'contract executed date' in the new column.
Sample data:
Contract No.Contract Received dateContract Executed DateNew Column
22
7/7/20224/17/20234/17/2023
22
22
8/7/20221/11/20224/17/2023
22
2311/4/20237/8/20214/6/2021
2311/4/20237/8/2021 4/6/2021
232/9/20234/6/2021 4/6/2021
245/8/20211/1/20211/1/2021
249/9/20232/2/20221/1/2021
Could someone please help with the DAX to achieve this result?
Thank you
  • and you can try this
    DateNew2 =
    VAR t1 = 'Table'[Contract No.]
    VAR t2 = ALLEXCEPT( 'Table', 'Table'[Contract No.] )
    VAR t3 = CALCULATE( MIN( 'Table'[Contract Received date] ),t2  )
        CALCULATE(MIN('Table'[Contract Executed Date]),t2,
            'Table'[Contract No.] = t1 && 'Table'[Contract Received date] = t3
  • pls try this
    DateNew =
    VAR t2 = CALCULATE( MIN( 'Table'[Contract Received date] ), ALLEXCEPT( 'Table', 'Table'[Contract No.] ) )
        MINX(
            FILTER( ALL( 'Table' ), 'Table'[Contract No.] = t1 && 'Table'[Contract Received date] = t2 ),
    DateNew2 =
    • Ahmedx's avatar
      Ahmedx
      sorry you can shorten the code further try this
      DateNew2 =
          CALCULATE(
      • POSPOS's avatar
        POSPOS
        This worked too! thank you for the solution
