Justin_Dybedahl's avatar
Justin_Dybedahl
2 years ago
Comparing two values between tables
I'm writing a report on M365 data and I'm trying to create a column in a table visual that shows if the version of M365 is supported by Microsoft.  My issue here is that I'm trying to compare the two...
  • Jihwan_Kim's avatar
    2 years ago
    I am not sure if I understood your question correctly, but please check the below picture and the attached pbix file whether it suits your requirement.
    expected result CC =
    VAR _condition =
            COUNTROWS ( 'supported versions' ),
            TREATAS (
                SUMMARIZE (
                    FILTER (
                        'device inventory',
                        'device inventory'[Device Name] = EARLIER ( 'device inventory'[Device Name] )
                            && 'device inventory'[Username] = EARLIER ( 'device inventory'[Username] )
                    'device inventory'[Build Version],
                    'device inventory'[Channel]
                'supported versions'[Build Version],
                'supported versions'[Channel]
        ) >= 1
        IF ( _condition, "Yes", "No" )
