Anonymous's avatar
7 years ago
Compare Values in Column Between Two Tables - Help with DAX Expression
I would like to write a DAX statement that compares the values of a column in Table A to a column in Table B.
Table A has unique values
Table B has duplicate values because the data represented is daily performance
Rough expression of the logic:
If the Transation ID in Column X of Table A matches a Transaction ID in Column Y of Table B, True else False.
Thanks!
    Hi Anonymous
    Try this
    New column = IF ( TableX[TrnsactionID] = RELATED( TableY[TransactionID]), TRUE(),FALSE() )
    Raj
      I used this logic based on your recommendation:
      Column = IF(Inv[UID]=RELATED(Sheet1[UID]),"Sold","Available")
      The output in thge table view looks like this:
      However, when I am in the Data View the column shows Available and Sold.  I can't figure out why I can't show "Available" on my table visualiizaiton.
      • v-danhe-msft's avatar
        v-danhe-msft
        Hi Anonymous,
        Could you please share a sample data to have a test and post your desired result if possible?
        Daniel He
