Compare two cells using DAX or Power Query
I want to check if all values in Souce column exist in Target Column.
If I can get True or False, it's good.
If I can get Exact value that's missing, it's better.
| Cell_Id | Source | Target | Check Source in Target? | Check Source in Target? |
| KNJ01002A11 | 389090,507870,520110,126490 | 389090,126490,505950,520110 | FALSE | Missing 507870 |
| KNJ01002A21 | 389090,507870,126490,520110 | 389090,126490,505950,520110 | FALSE | Missing 507870 |
| KNJ01002A31 | 389090,507870,126490,520110 | 389090,126490,505950,520110 | FALSE | Missing 507870 |
| ANJ01002A11 | 389090,507870,505950,520110,126490 | 389090,126490,505950,520110 | FALSE | Missing 507870 |
| ANJ01002A21 | 389090,507870,505950,520110,126490 | 389090,126490,505950,520110 | FALSE | Missing 507870 |
| ANJ01002A31 | 389090,507870,505950,520110,126490 | 389090,126490,505950,520110 | FALSE | Missing 507870 |
| ANJ01002A12 | 505950,520110 | 389090,126490,505950,520110 | TRUE | All Exist |
| ANJ01002A22 | 505950,520110 | 389090,126490,505950,520110 | TRUE | All Exist |
| ANJ01002A32 | 505950,520110 | 389090,126490,505950,520110 | TRUE | All Exist |
your solution worked perfectly. Can't thank you enough for your help.
Only thing I need is "," between the result like shown below.
Actual Result: Missing 126490389090
Result I need: Missing 126490,389090
Hi PSB
I updated the link yesterday to reflect the changes to CONCATENATEX's delimiter.
I hope it works for you.
- Idrissshatila
Hello PSB ,
You could add a calculated column with the following measure
Check Source in Target = IF('Table'[Source] = 'Table'[Target], "True","false")If I answered your question, please mark my post as solution, Appreciate your Kudos 👍
- grantsamborn
Solution Sage
Hi PSB
I made a couple of transformations in Power Query:
- separate Source from Target
- unpivot both tables
- create DimCell
After that, there is a single measure to concatenate any values that weren't found.
Let me know if this works.
(edited to change link - I forgot the delimiter in CONCATENATEX.)
https://1drv.ms/u/s!AnF6rI36HAVkhPIcSilVrS2tpNBEQg?e=ApDvy6
- PSB
Helper III
- grantsamborn
Solution Sage
Hi PSB
- PSB
Helper III
I want to flag as true even if source is "123-234" and Target is "012-123-234-013"
