circular dependency --help please
hi
i am just trying to relate tables using bridge table . where i am facing the circlaur dependency .
dim:
feedyard
sex
ration
data table :
feedyard sex ration index
alex bike 1200 0
alex car 6000 1
alex house 2000 2
created the bridge table :
Hi Anonymous
1. copy "dimension" and paste, then i get "dimension2" table,
in this table with only one column, "remove rows"->remove duplicates
2. copy "data" and paste, then i get "data2" table,
in this table, click on the [index] column and select "Remove other columns", then Removed Duplicates
3.in "dimension2" table, add a custome column
Then expand this column
Maggie
- AnonymousNot applicable
What does your overall table structure look like? Do you have many bi-directional relationships? Bi-directional 1 to many relationships are often the easy way to fall prey to this issue. The other cause could be if you have created a loop within your actual structure, whereby you might have to make a relationship inactive and make use of USERELATIONSHIP in dax if there is a special case.
HI Anonymous
i dont have any tables other than 3 .Ataching the screenshot . Do you mean that table which i am creating by the use of cross join is causing the issue ?
I notice the Cardinality and Filter direction are blank. Those options shouldn't be blank, and it shouldn't even let you select blank. Something is very broken here.
Are you able to select cardinality?
- v-juanli-msftCommunity Support
Hi Anonymous
You use 'dimension'[dim] to create the bridge table, then create the relationship between 'dimension' and "check" table, so it occurs an error for circular dependency.
More introduction about avoiding circular dependency please read this article.
As a workaround, you could create this bridge table in Edit Queries.
Create a blank query, then paste the following code in Advanced editor
let Source1 = dimension, #"Removed Duplicates" = Table.Distinct(Source1), Source2 = data, #"Removed Other Columns" = Table.SelectColumns(Source2,{"index"}), #"Removed Duplicates2" = Table.Distinct(#"Removed Other Columns"), addcolumn=Table.AddColumn(#"Removed Duplicates", "index", each #"Removed Duplicates2"), #"Expanded index" = Table.ExpandTableColumn(addcolumn, "index", {"index"}, {"index.index"}) in #"Expanded index"Or you can edit the table steps by steps with the UI
1.Query1:
copy and paste the 'dim' table->Removed Duplicates
2.Query2:
copy and paste the 'data' table->click on the [index] column and select "Remove other columns"->Removed Duplicates
3.in Query1:
Add column from Query2 , then expand the column
Maggie
will this table gets refreshed will scheduled in prod?. I mean if the values (attributes)gets added to the dimension ( productname say) will this data be also reflects to the bridge table automatically without manual intervension?
one more question : if i paste the query using query editor will this query creates other two tales and then join ?. Will this step refreshes the data in bridge table based on data change other two tables ?
3.in Query1:
Add column from Query2 , then expand the column .
can you send me screenshot how you did this from query editor . I am not able to add column from another table .can you help here ?
